Machine Vision
Problems acquiring images with grab function
I'm using the PCI-1411 with a camera connected to the S-video. I tested the camera in Max and it worked very good. But, in Labview 7.1 I have an application using the grab function to capture only one image instead of the snap. I'm using the grab because of the speed. The problem is that some time the image appears like divided in three or four parts, and some times appears good(Please see attached file for reference). I have the same applicacion with a monochromatic camera and that never happen. I also connect the camera with the BNC conncetor with the same results.
(3,090 Views)
Hi Jacob,
I was thinking about your issue and came up with this KnowledgeBase that might help you out.
http://digital.ni.com/public.nsf/websearch/A1F031E6269D9E3B86256EFB0068807D?OpenDocument
Within this document there are a few things you may want to check, along with a smaple image that has some similar characteristics of yours with part of the image wrapping around to the other side. Let me know if this helps you out.
Regards
Dan Q
(3,051 Views)
