Machine Vision
Problem with Vision Builder - Open previous version VI
Hello!
I'm having a problem with Ni Vision Builder 2.6.1, when I try to open a .vi made in Labview8.0 and saved with the "Save for previous version" to Labview 7.1.
In NI Vision Builder 2.6.1 when I try to open a .vi for the "Run LabVIEW VI" it gives me the following error message: "There is no VI at the path you specified", when there's a .vi there and it has been downgraded to Labview 7.1 as explained before...
The reason I made the "downgrade" of the .vi file, was a note in the Vision Builder help menu: " Note  The Run LabVIEW VI step works only with VIs saved using LabVIEW 7.1. ..."
Any help would be greatly appreciated!
Thanks in advance!
(4,591 Views)
HI
I send you a link which is likely to help you.....
http://digital.ni.com/public.nsf/allkb/9a7fd7e615a18e518625709200778fd5
If you want more information send me an example, i will test it for you...
good luck!
Kamal
(4,574 Views)
Hi!
Thank you for your reply, but the problem you refer is not the one I'm having...
My problem is not related with exporting the "Vision Builder" Inspection to Labview, but the opposite, i.e, "Run Labview VI" in the Vision Builder.
(4,570 Views)
hi
 i have found a way to solve this kind of problem, but it is not a way you can use because you don't have the LV 7.1:
- Save your vi made in LV 8 in previous version, so in LV 7.1
- Open this vi with Labview 7.1 and save it without modification
- Import the vi in the Vision Builder
I try to find an other way to help you, i will send you a message later...
sincerly,
Kamal
(4,549 Views)
We do have the same problem with VBAI 3.0.1 which accepts only VIs saved with labview 8.0.
Here we only have labview 8.5 and when we "save as" for previous version, VBAI says "There is no VI at the path you specify"
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(4,221 Views)
