Machine Vision
Problem IMAQdx
HI,
I had develop a puppilometer with ethernet camera (Axis), labview 8.5 and Ni vison 8.5. It´s work fine in windows vista and XP. Now I need change to firewire camera (firefly MV - PointGrrey). I download example program MotinDetect IMADdx_lv85 to learn about firewire camera, but it inst work. I had detect my  problem but i don´t fix it.
First I detect that IMAQdx is install in Labview
Second Vision Aquision software it is installed and activated
But IMAQdx doens´t present in Devices Interface in MAX
what´s wrong in my instalation?
John
(5,255 Views)
You need to have installed the drivers below:
NI-IMAQ 3.8
NI-IMAQdx 3.1
NI-IMAQ I/O 2.1
Best Regards
Cesar Federice
National Instruments Brazil
(5,222 Views)
I have a similar problem,
I'm trying to use a VDS camera with gigabith ethernet connection.
I'm now able to use it with original software, but I'm not able to see it using NI software. I have installed Vision 8.5.1 with NI-IMAQdx 3.1.2 software, but when I go to MAX it si not able to see the camera. Moreover, in "devices and interfaces" I don't have the folder "NI-IMAQdx devices" and even in the help topics I have nothing that refers to NI-IMAQdx.
On the contrary, in the software tree I have NI-IMAQdx 3.1.2 installed.
Why I cannot see the camera with MAX?
Is there some problem with the installation? I already tried several times.
In attach you can find a picture of max
Thank you in advance for you kind help,
Sincerely
Emanuele
(4,944 Views)
Please, try to install the DAQmx again and select to install the options below:
NI-IMAQdx
NI-IMAQ I/O
24096iA06B6A9C11376A80
(4,929 Views)
dear cfederice,
it seems that I already have installed the software you suggested me.
I attach a picture of my MAX
thank you
emanuele
(4,906 Views)
Please, see the configurations of hardware and software that you need :
Hardware
  • GigE Vision camera: The camera must be GigE Vision standard compliant. If you have a camera that has a Gigabit Ethernet port but is not GigE Vision compliant, you cannot acquire images using Vision Acquisition Software. You should find the GigE Vision logo in the camera's user manual or marketing literature.
  • Gigabit Ethernet port: While it is possible to acquire images with Ethernet and Fast Ethernet ports, which support 10 MB/s and 100 MB/s respectively, this will only work at very slow frame rates and small resolutions. It is highly recommended that you use a Gigabit Ethernet Network Interface Controller (NIC).
Software
  • Vision Acquisition Software: You will need Vision Acquisition Software 8.2.1 or higher, which will install NI-IMAQdx 3.0 or higher. NI-IMAQdx is the driver that includes the functionality to acquire images from both GigE Vision and IEEE 1394 cameras.
  • Application Development Interface (ADE): You can use LabVIEW, LabWindows/CVI, Visual Studio 6.0, Visual Studio .NET or any ANSI C compiler to acquire images
Links:
https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0UsCAI&l=en-US
Best Regards
Cesar Federice
(4,891 Views)
