Machine Vision
Plotting Discrete Histogram
I tried to plot the contrast information of an image using the IMAQ histogram., But the output of this vi does not have a IMAQ display associated with it.  Even when I tried to use the built in LabVIEW graphs to display the histogram, it gives a continous plot.
Is there any VI I can use to display a discrete histotram plot as shown in the attached picture.
Thank you.
(4,709 Views)
Instead of IMAQ histogram, use IMAQ histograph.vi (vision and motion > image processing > analysis > ...), and connect a waveform graph to the histogram graph output. Then choose a bar plot style.
Chilly Charly    (aka CC)
(4,704 Views)
Thank you Chilly. I did what you suggested, however, I can not change the waveform plot to bar plot.
There is no option to change it to bar plot.
I have attached the VI .
Thanks.
(4,689 Views)
Right-clic on the graph > Visible items > plot legend
then clic on legend > bar plots... 🙂
(4,680 Views)
Thank you very much Chilly.
Have a pleasant weekend
(4,675 Views)
