Machine Vision
Pixelwise rectification in the Stereo library
I'm working with the Machine Vision Stereo library where I'm trying to calibrate two cameras and do some measuring of different objects. The example works fine, however as far as I can see there are no option to rectify only a single pixel coordinate from each camera. In stead, you have to rectify the whole image before you can calculate the disparity. I understand that this is the standard way to do it, but since I already have the coordinates of the pixels I want to measure, I'm wasting a lot of time/resources by rectifying the entire image.
In other words I need either the look-up table or/and the homography matrix that IMAQ Get Rectified Image From Stereo VI uses, but as far as I can see this is information is not available. Is there perhaps a way to access the IMAQ Binocular Stereo Session, since the information most likely is hidden there?
(4,744 Views)
yes I would say that the information regarding the rectification matrix for each camera must be hidden in the stereo calibration output, but I don't think this can be accessed.
At least not without knowing how NI codes this information in a file. The documentation and support regarding this is not so good in my experience.
If you want, you can use OpenCV stereo in Labview (via .dll calls). I have created both the calibration and measurement interface in Labview. The calibration also returns the rectification matrix for each camera. Take a look at this:
https://decibel.ni.com/content/blogs/kl3m3n/2015/08/28/stereo-vision-opencv-and-labview-comparison
Hope this helps in anyway.
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,717 Views)
