Machine Vision
Pixels Conversion
I'm using a CCD with resolution of 768 X 494 pixels and a focusing lens of
magnification 25 times.
When i grab an image using the above and taking distance measurements of
particles in the image in terms of pixels,
what is the physical sense of these measurements in pixels??
(4,637 Views)
You can calibrate your system to have real world coordinate correspond with pixels. There are three type of correction to obtain the real world measurements from your image: simple calibration (so many units equal so many pixels in the x and y direction), there is perspective calibration(if your camera is at an angle), and non-linear lens distortion. These are all described in more detail in the Vision Concepts manual
LV6\Vision\322916a.pdf
There are also shipping examples to help illustrate these methods under labview6/examples/vision/2. functions/calibration/
Hope this helps,
Brad
(4,637 Views)
