Okay, here are a few clarifications:
The PNG file saved by MAX and LabVIEW is not 100% compatible with other programs. It will load with other programs, but looks very dark. If you look very, very closely you may see some of the details of your image that are very faint.
In MAX, you can't do much other than save a PNG file. You can't do conversions (unless the camera can be set to 8 bit mode, which would solve all your problems).
In LabVIEW, the routine IMAQ Cast Image is available if you have the Vision toolkit. You can find it in Vision help, or look under Vision Utilities -> Image Management on the Vision palette. I would try a bit shift of 2 before trying to create custom LUTs, because it is much simpler.
B
ruce
Bruce Ammons
Ammons Engineering
