Machine Vision
Phantom high speed camera compatibility
I have a Phantom Miro high speed camera and I want to use labview to control the camera. I have a driver which is compatible with Labview 7.1. But my labview version is 8.5.
My problem is when I opened the 'quick start' vi file, which is an example from the drive, after installed the driver, The labview will  terminate immediately  itself. I am not sure what's the issue. Could you please recommend a driver which can make my Phantom Miro camera is compatible with Labview 8.5.
Thank you!
Melody
(5,099 Views)
Hi Melody,
What hardware interface are you using - Camerlink, GigE, FireWire, Analog, Parallel Digital? If you are not using an National Instruments frame grabber or if the camera is not GigE or DCAM (FireWire) compliant then I cannot recommend an NI driver for you as these are the interfaces we provide support for.
This sounds like a third party driver, not an National Instruments driver. Can you confirm this? If so, try contacting the driver developers. You should be able to find what versions of LabVIEW the driver is compatible with in the driver's documentation...you could probably find more information on contacting the developers there, too.
Does this help?
--Michelle
(5,087 Views)
(5,083 Views)
Thank you Michelle. I will try to ask the manufacturer of my camera first. This camera is Ethernet.
Melody
(5,069 Views)
Hi Pkozik,
Thank you for your suggestion. I'll give it a try.
Melody
(5,068 Views)
