Machine Vision
Pattern tracking
Hi All,
i need to track a pattern and calculate its centroid. I have Vision and IMAQ modules.
I'm totally new to LabView and i understad that this software has many capabilities and a lot of features.
Could you suggest me the features which i should learn in order to solve my task ?
Andrea
Message 1 of 8
(5,155 Views)
Hi Andrea
Welcome to LabVIEW WORLD.
This questions asked many times for solved solution check here. Note:For Live Acqusition you have to modify bit of this code.
Silver_Shaper | CLD
Message 2 of 8
(5,152 Views)
Hi Kudos,
thanks for suggesting me your code, but it is not working.
After loading the file, i get the error
"Error 1074396009 occured at IMAQ AVI open
Possible reason(s):
IMAQ vision: an internal DirectX error has occured. Try upgrading to the lastest version of DirecX"
I upgraded to the last version of DirectX, but this does not solve.
Andrea
Message 3 of 8
(5,085 Views)
Hi Andrea
Look at this thread for error solution http://forums.ni.com/t5/Machine-Vision/DirectX-Error-playing-AVI-file/td-p/1089274
Silver_Shaper | CLD
Message 4 of 8
(5,077 Views)
Unfortunately the solution you suggested is not working for me. I continue to get the same error.
In any case, please note that i do not need to track an object in an AVI file, i need to track an object from a webcam
Could you suggest also a solution for this ?
Andrea
Message 5 of 8
(5,070 Views)
Hi Andrea,
here you can find a lot of NI Vision Development Module that you can use in order to realize your application.
I think they are very useful.
Hoping they will help you.
Best regards.
Claudio C.
Message 6 of 8
(5,063 Views)
Hi Andrea,
Is there any improvement on your code
Silver_Shaper | CLD
Message 7 of 8
(5,051 Views)
In this illustrative example, we will create a program in Labview capture an image pattern, after the search to show the location and coordinates, you can check the following article in the following link
https://decibel.ni.com/content/docs/DOC-31880
Message 8 of 8
(4,687 Views)
