Machine Vision
Pattern matching- get best match
I am trying to find a way to use the pattern match tool to get the best match of a group of parts.  Once I get the best match I need to apply other vision tools to the best matched part to get a proper orientation for a robot pick operation.
Right now this is what I am doing:
1) Get matches to pattern (usually I get about 6)
2) Assign coordinate system to first match (would love to be able to assign to best match but can't find a way to do it).
3) Apply other vision tools to first match to find small part feature to get part orientation for a pick operation.
(This method works most of the time but I need to improve it.  If I could use the best match instead of the first match, then I think my success rate would improve greatly.)
I know I can get an array of matches and then search the array to get the best match but I can't figure out how to do this while staying in a NI Vision routine.  Is there a way to choose the best match while still in a vision routine, or is there a way to apply a coordinate system to a match after leaving NI vision and returning to LabVIEW so that when I reenter NI vision, I can apply that coordinate system to the best match part from a previous pattern match?
Thank You
(2,322 Views)
Hey Vimes,
Are you trying to do Pattern Matching in VBAI, Vision Assistant or LabVIEW?
Ryan B.
Technical Support Engineer
(2,282 Views)
I'm using Vision Assistant and LabVIEW.  NI support replied to me and said if I set the number of requested matches to one, then it will report back the best match.  That has helped somewhat.  I still have issues with getting pattern match boundaries to land in the proper place but that's a different issue.  Thanks.
(2,266 Views)
