Machine Vision
Pattern Tracking
I am working with LabVIEW 2010, the starter kit 1.0 and an axis m1011 camera. I want to track and follow a known pattern by comparing and matching with a template that will be saved in the robot's memory, I've having a real hard time with this and would really appreciate some help.
(3,918 Views)
Hi
Check this might help you.
Silver_Shaper | CLD
(3,905 Views)
Thank you for your reply, but there is a sub VI missing, "Draw Pattern Matches Position" so I cant open it. Also I think I wasn't to clear about the last part, when I say follow the pattern i mean the robot drives towards it.
(3,894 Views)
@zhoudeng wrote:
But there is a sub VI missing, "Draw Pattern Matches Position" so I cant open it.
Open this Example Vision Development Module Image Processing Examples » Pattern Matching Example you can find the subvi here.
Silver_Shaper | CLD
(3,886 Views)
