Machine Vision
Pattern Recognition error
I have this little program which finds multiple patterns but i have a problem with the IMAQ Read Image And Vision block. It give me this error "error -1074395995".
I put the right path of the patterns folder but still the same error. Can someone help me?
Best regards.
Message 1 of 8
(7,576 Views)
Put a probe at "File Path input terminal" of IMAQ Read Image and Vision Info and see whether the path expected is coming properly.
-I think it is not and hence you are getting error. Please adjust the build path to point to right location of template images....
uday
Message 2 of 8
(7,573 Views)
I don't know how to put a probe at that terminal 😄 can you help me or describe in detail how to to do that?
Best regards.
Message 3 of 8
(7,572 Views)
Create a new vi, Drag this image into labview block diagram.
Run the vi and take screenshot of what the path indicators are giving and post.
To use probe, while the vi is running, you need to go that wire and right click and you should be able to see probe window...for more
https://www.ni.com/docs/en-US/bundle/labview/page/using-the-probe-tool.html
uday
Message 4 of 8
(7,567 Views)
This is the result
Message 5 of 8
(7,561 Views)
Message 6 of 8
(7,560 Views)
Can you provide the path location where your template images are?
-From the screenshot it's clear that the paths are not correct can you notice that?
-If you have images at C:\Users\User\Desktop\road signs\Multiple Geometric matching\Template\ path then please remove "r2.png" after road signs.....
-Then please verify the Array of paths is coming properly!!!
uday
Message 7 of 8
(7,553 Views)
After many attempts i've solved that problem but now i've got discove another problem :
Error -1074395628 occurred at IMAQ Learn Multiple Geometric Patterns
I creeated my template with NI Vision template editor from Vision Assistant and my VI still not recognize my template from my folder.
Any help?
Thanks a lot.
Message 8 of 8
(7,519 Views)
