Machine Vision
Pattern Matching
I would like to know the difference between the various types of VI's specifically designed for pattern matching- IMAQ Match Pattern 2, IMAQ Match Pattern 3 and IMAQ Match Pattern 4. Also, it'd be helpful if you could elaborate on the kind of task each of these VI's can be used for.
Robot Embarassed
(4,018 Views)
as I know it enhance in algorithm any version  and some feature are add to this vi any version and they become better any version
for example in version 4 you can also select witch algorithm to use
(4,004 Views)
