Machine Vision
Particle filter for grayscale objects shall not deliver binary images.
Hi freaks,
I have grayscale images with a small number of objects of various sizes. I apply IMAQ particle filter 2.vi in order to keep only those particles which exceed a certain limit for their area. The vi works well but unfortunately it returns a binary image. However, I need the grayscale information of the particles which survived the filtering. Any idea how I can keep the big grayscale objects and reject the small ones without transforming the big ones to binary format?
Thanks a lot in advance,
Peter
(3,615 Views)
Peter -
One idea that springs to mind is to take the binary output of IMAQ Particle Filter 2 and use it to mask the original image (with the IMAQ Mask VI) to only keep those particles in the original image.
Greg Stoll
IMAQ R&D
Greg Stoll
LabVIEW R&D
(3,606 Views)
Use the filtered binary image as a mask on your original image using the Mask function. If I understand you correctly, that should be exactly what you want.
Kevin
(3,604 Views)
Kevin, Greg,
your answers helped. Thank you!
Peter
(3,598 Views)
