02-08-2006 04:36 PM
I am using the PCIe1430 succesffully from MAX to acquire images from two Pulnix Color Cameras (TMC-1400CL). In my Labview Code also I could read the image information fine from the Port 0. But I havn't been able to figure out how can I address the camera connected on the other Port, which is Port 1.
I would appreciate if you guys could send me a vi showing the addressing format for the two ports. (I have tried img0:port0 etc but it didn't seem to work)
Thanks in advance.
02-09-2006 12:06 PM
K_seeker,
Have you tried...
img0::1
This should work. If it doesn't, tell me.
Good Luck,
Lorne Hengst
Application Engineer
02-09-2006 12:18 PM
