Machine Vision
PCIe 1429 failed to load ICD file
Dear everyone
 I have a NI PCIe-1429 frame grabber and a Basler acA2000-340km camera ,but the NI measurement & automation explorer 5.3.1 failed to load the ICD file of this camera even all the Basler acA2000 series and just give me a message as
"Error 0xBFF60108
the camera file does not support the current interface type."
However, it can load the other ICD files normally.I had used a Basler A504k camera,it was working  normally.
All  the NI softwares and drivers are the latest.
Can anyone give me a solution to resolve the problem?
(4,049 Views)
I don't think that hardware supports the Basler camera. Have a look over here:
www.ni.com/camera/
You might be better off contacting Basler or NI to see if they have a camera file that supports that camera for the framegrabber you are using.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,986 Views)
Actually it should work. What Tap configuration do you need.
Christian
(3,980 Views)
I have used this camera multiple times in the past.
If you can post the camera file you're using, I should be able to help make a few minor changes to let the 1429 work as well.
-Daniel
(3,951 Views)
