Machine Vision
PCI-1428 no VSYNC lock
Using IMAQ 3.1.1.3004 with a PCI-1428 board, we get a scrolling live image from the camera. The camera is a Pulnix TM-6710CL with a CameraLink connection to the board. I assume the problem is a sync problem, but see no way to configure it with in Measurement & Automation Explorer.
(2,991 Views)
TajMahal,
Camera files are used so the board knows how to interpret data from the camera.  If you are not using the correct camera file, you can get the behavior described above.  To get the correct camera file, right click on this link: Pulnix 6710CL.icd, select Save Target As... and save the camera file to your C:\Program Files\National Instruments\NI-IMAQ\Data directory.  Now you can select this camera file in MAX.  Hopefully this will correct the issue.
Ryan M.
(2,970 Views)
