Machine Vision
PCI-1422 Problem
Is the 1424 card working in a different computer?  Also what version of the IMAQ driver are you using?  Since you are using Windows 2000 you can use the latest version of the Vision Acquistion Software (8.2.3).  If you are using an older version go ahead and try upgrading to the latest version.  Also when do you recieve the memory 0 error?
Keep me posted.
GG
Message 11 of 14
(1,935 Views)
 I'm using PCI-1422 to develop a project, but I don't kown how to use the control signal(control0,control1,control2,control3 in the output pins)  to control my digital camera.  I want to kown if there is any function in IMAQ to control the signal, but I haven't find it yet. Expected to your reply sincerely.
Message 12 of 14
(1,787 Views)
Hi Qianlian,
What do you want to control using the Control lines?
If you want to do Digital Input/Ouput, you will need the IMAQ I/O drivers.  If you are hoping to output a trigger or a pattern, you will need to modify the camera file using the Camera File Generator found here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14207
Rishi L
Message 13 of 14
(1,772 Views)
How can I control the frame rate through PCI-1422? Is there any function in niimaq.lib to  set the frame rate? I find the NI software MAX can modify the frame rate, now I want to know how to set the frame rate through programming with C++.
Message 14 of 14
(1,485 Views)
