Machine Vision
PCB inspection system
What is the conventional lighting used for PCB inspection system.I tried a linear bar led from 4 sides with a tilt but am not satisfied with the result.Can you guys suggest me the suitable lighting ?
(4,935 Views)
Accepted by topic author muks
If using a line camera, a line light on either side works great.  For area scan cameras, you need to uniformly light the area with diffuse light.  For a small area, you can use something like the CDI (cloudy day illuminator).  For a large area, you could make your own dome like surface and point some lights into it.  For one project I did many years ago, we built a square pyramid shaped dome, painted it white, and put a linear bar along each edge pointing up at the dome.  It wasn't perfect, but it did the job.  The important thing is to point your light at a large white surface, and let the reflection of that light illuminate the part.  You might be able to do it by putting some fluorescent lights behind a large diffuser panel.
Bruce
Bruce Ammons
Ammons Engineering
(4,930 Views)
Tried the same with a n array of leds.Still am not able to get consistent lighting. due to the irregular surface......
(4,925 Views)
What size is the area that you are inspecting?  What makes the surface irregular?  What are you trying to inspect?
Bruce
Bruce Ammons
Ammons Engineering
(4,920 Views)
I need to inspect everything from resistor ,capacitors  and it contains not only SMD components but also through hole and the through hole components has flexibilty .  And  i need to provide an inspection system for  various sizes  with different set of mechanical aligners.
(4,889 Views)
Hi muks,
I think it might be helpful if you gave us a little better idea of the size.  Are we talking a few inches or a few feet?  I would suggest taking a look at this Developer Zone article A Practical Guide to Machine Vision Lighting – Part III.  I think it may give you some good ideas about the options you have available as far as lighting.
Adam H
(4,865 Views)
Thanx adams for the link
(4,853 Views)
