Hi there,
Are you using LabVIEW? If so then try looking for the example code "Golern Template Inspection Example.vi"
(if you go to help>>find examples>>search tab at the top right>>search for templeates and double click this in the left list>>Select the vi mentioned above.
The overlay is achieved in this vi by creating a custom colour palette.
Hope this helps
Adam
Message Edited by AdamB on 01-08-2007 03:20 AM
Applications Engineering Team Leader | National Instruments | UK & Ireland
