Machine Vision
OCR specifications
What are the minimum specifications / recommendations or guidelines to
follow in order to have a 100% match using NI OCR.
(Please add the ones I'm missing)
-like background color, foreground color, font type, font size,
spacing, pixel quality,..
(3,236 Views)
It would be hard to tell you everything you need to do for OCR to work, especially 100%.  Here are a few things to consider, though:
Make sure your characters can be separated from the background and each other easily using standard thresholding.  It is easier if the characters are a solid stroke with medium to thick lines.
Make sure your characters are easily distinguished from each other.  The classic case is 0 and O (number and letter), which are very difficult to distinguish unless the zero has a slash through it.
I think for good OCR, the height of each character should be 20 pixels or more.  You don't want to get too large, though.
There are a few other things that depend on the application that I can't guess at, such as lighting, camera selection, etc.
Bruce
Bruce Ammons
Ammons Engineering
(3,219 Views)
