Machine Vision
OCR: Save text parameter in multi-session
Hi, I have a problem with saving the parameter trained with OCR Train. The problem is that I do not have all the alphabet to train on the same picture and in the same time. It can happened that now I get the 80% of the alphabet but I will have the last characters after 1 month.
1) Do I have to train every character that I have to read?
2) Using the function "Write character set file", is it possible to append the parameter of the last character? Or every time I use the function I overwrite the file?
Thanks a lot.
Ciao Edo.
(3,132 Views)
Is not possible !
The only chance you have to install and use Vision Builder to make easy access to the .abc file created by OCR tools, other wise you should train all the alphabetic character set.
Ciao
(3,121 Views)
