Machine Vision
Ni-Imaq programing on camera hardware binning
I am trying to write an image acquisition program in C++ using NI-Imaq library.
I have no problem acquiring the saving the images without any binning, but my application requries binning to get higher
frame rate.  The camera I am using is Imperx IPX-2M30-L and the framer grabber is PCI-1428.  The camera is capable
of doing 2, 4 and 8 binning in both directions.  I was hoping to use IMG_ATTR_VSCALE and IMG_ATTR_HSCAL, but
only got invalid value for IMG_ATTR_VSCALE error.  Is that because IMG_ATTR_VSCALE is deprecated and is not supported?
Is there anyway to do the binning and still be able to acquire images with imgRingSetup and imgSessionCopyBuffer?
Thanks a lot,
Travis
(3,382 Views)
You need to set binning on the camera, and this is done with the camera file. The camera file for your camera has a binning section at the bottom. Open MAX and go to your camera attributes and you'll see a binning feature at the very bottom. Set this to Vertical and Horizontal and acquire and you should see the faster frame rate in MAX and your C program when you save these settings.
The NI-IMAQ attribute you were using scales the image returned by the camera and so it wouldn't increase the frame rate of the camera. I think they are only valid for analog cameras.
Hope this helps,
Brad
(3,379 Views)
