Machine Vision
NI IMAQ Vision run-time engine 7.0
I built an executable software with LabVIEW 7.1
To develop the source it was used the NI-IMAQ Vision 7.0 and NI-IMAQ 3.1.1 drivers.
The executable worked fine on a target PC where both the NI LabVIEW Run-Time Engine 7.1 and the NI IMAQ Vision Runtime Engine 7.0 were installed.
Now I'm trying to run the executable on a new target PC but I have some problems, I presume, concerning the image maching, i.e. something concerning the VISION library.
On this new target PC I have installed the IMAQ Vision Runtime Engine 7.0.1 because the IMAQ Vision Runtime Engine 7.0 is not present anymore on the www.ni.com website.
Is it possible that this could be the reason of the problems?
If the answear is positive, where could I download the IMAQ Vision Runtime Engine 7.0?
Thank you very much
GcDago
(3,701 Views)
yes it is possible, you need to have the same version of runtime.
At ni.com (see following link):
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0D10?opendocument&node=132070_US
you'll able to download only updates of the IMAQ Run-time Engine version.
I suggest to you to contact your National Instruments sales representative to obtain the IMAQ Run-time Engine Version 7.0 for Windows 2000/95/98/NT/XP--Deployment Engine.
Best, regards
AmbuA
(3,678 Views)
