04-29-2009 02:55 PM
I am trying to get MAX and ultimately LabView to detect my digital camera. The camera was originally manufactured by Optronics but is now technically under Olympus. The camera works fine with a third party software (MagnaFire) and is detected under device managers. However, MAX cannot detect the 1394 FireWire port and as a result the camera has been unusable. Now the tricky part is that the current OS (Windows XP) had to be reverted back to the SP1 1394 drivers due to the ohci compliance issues with SP2 in order for the camera to be detected by the device manager. If anybody has any solutions that would be great.
LabView 7.1
IMAQ 1394 2.0.5 (30 day trial)
04-29-2009
06:20 PM
- last edited on
04-01-2025
09:02 AM
by
Content Cleaner
For the camera to show up in MAX, it not only has to have a firewire output, the firewire output has to be IIDC compliant, see http://digital.ni.com/public.nsf/allkb/9FFF247558F4A51C86257418007C95EA . It is not obvious that all of the Optronics cameras are IIDC compliant, see http://damien.douxchamps.net/ieee1394/cameras/search/o/. What is the model of your Optronics camera?
If the camera manufacturer provides a DirectShow, you may be able to use the NI-IMAQ for USB camera driver to acquire images from the camera into LabVIEW, see http://zone.ni.com/devzone/cda/epd/p/id/5030.
05-04-2009 12:13 PM
05-04-2009 12:45 PM
Do you have a model number for the Magnafire camera?
05-04-2009 01:27 PM
Sorry to make this difficult but there are three different numbers attached to it and I'm not sure which one it is. They are as follows:
U-TLU 9J01266
U-CMAD-2
U-TV1X
05-04-2009 02:33 PM
05-05-2009 09:19 AM
All three of these items are camera accessories:
U-TLU is a Telan lens unit.
U-CMAD is a C-mount adapter ring.
U-TV1X is a lens.
You should contact Olympus to ask about IIDC/DCAM compliance.
