Machine Vision
NI GigE Vision Adapter Driver Code 12
We have a Problem with the Driver from National Instruments GigE Vision Adapter.
This device cannot find enough free resources that it can use. If you want to use this device, you will need to disable one of the other devices on this system. (Code 12)
We use normally the VAS (Vision Acquisition Software) Aug 2012 but i tried also with the VAS 2015 and Oct 2019. Neither works!
We have a new IPC from Axiomtek IPC962-511-DC-FL-6100T with Windows 7 Pro 64-Bit F and the PCI Card where we need the Driver from NI is, Ether Pro 1000 PT Dual PCIe x4 (EXPI9402PT)
The old IPC’s from Axiomtek 912, 914, 923…worked also with the same PCI Card.
Does someone can help us?
Thanks in advance.
Cheers
(2,706 Views)
Accepted by topic author SuYaKawa
The Problem was somewhere in the BIOS.
We installed the older BIOS Version SBC87511 V1.03 and it worked.
Bevor it was BIOS V1.04. installed on the IPC.
Cheers
(2,532 Views)
