Machine Vision
NI CVS
Good day,
I just want to ask if one CVS can cater 4 cameras simultaneously? How?
Your quick response will be much appreciated. Thanks.
(5,130 Views)
Hi Lelei,
What model of CVS do you have? Also, what communication/camera bus are you using for your cameras (e.g., USB 2.0, USB 3.0, GigE)?
Best Regards,
Kale
(5,108 Views)
Hi Kale,
Thanks for your response, I will use CVS 1457 and 4 GigE cameras.
(5,070 Views)
Accepted by topic author Lelei
Hi Lelei,
The CVS 1457 is designed to be used with one or two cameras. It may be possible to use a GigE splitter, but this is not supported so there's no guarantee that it will work.
- Kale
(5,059 Views)
Hi Lelei,
Thank you for your interest in NI Machine Vision products! As Kale mentioned, the CVS-1457RT has two dedicated Power Over Ethernet (PoE) ports. The use of multiple GigE cameras on a single port can be achieved through the use of a network switch, but you will of course be sharing bandwidth between multiple cameras. Please refer to this article for further information: Does NI-IMAQdx Support Multiple Cameras on a GigE Switch?
Also, what processing, if any, needs to be done on the images coming in from the 4 GigE cameras? If you need more processing power, the CVS-1458RT may be a better option.
Joseph
(5,050 Views)
Hi Kale and Joseph,
I really appreciate your response, i think these informations will be a big help.
Thanks.
(5,014 Views)
