Machine Vision
NI-1427 trigger problem with e2v camera
Hello, everyone
image.pngimage.pngI have a line-scan camera (e2v OCTOPLUS), which I connected to 1427 via the camera link, and my camera manual says: "External line trigger is provided by the frame grabber (CC1," I set up CC1 and external 0 in Digital IO in NI-MAX, My camera light will keep flashing (waiting for trigger). My next step is can I directly give a pulse wave to TTL-0 port of D-SUB15pin to achieve trigger? As if this does not achieve trigger (I use the periodic pulse wave generated by 6323 to ports 1 and 9 in Figure 2)
best regards
(1,862 Views)
Were you ever able to solve this problem? We've been struggling to externally trigger the octoplus camera via a similar 1433 card.
(1,339 Views)
