Machine Vision
Myrio image processing
  1. I'm using ni myrio for image processing project can the myrio work as a stand alone without labview connection hence the program won't contain any needed interactions
(3,081 Views)
Yep.  I believe what you are asking is if the myRIO is capable of running a startup executable and not need to be used in the LabVIEW Development environment.  I would try these links here and if you are unfamiliar with LabVIEW and myRIO I would consider ni.com/training for getting started help as well as the CompactRIO Developer's Guide
Deploy a Startup Application to Your MyRIO
NI myRIO: Deploy a stand-alone application
Hope this helps!
Bear
Ben Johnson
ʕง•ᴥ•ʔง
(3,005 Views)
