Machine Vision
Multiple ROIs for Pattern matching
I want to define multiple regions of interest for pattern matching so that if one fails an alternative ROI might be used.The acquistion is continuous. I have a system that works with single ROI. I want to use the same with multiple ROI.
(3,731 Views)
Are you looking for the following examples?
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E07356A4E034080020E74861&p_node=DZ52500&p_source=external
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E8E356A4E034080020E74861&p_node=DZ52505&p_source=external
Hope it helps.
(3,731 Views)
Dear sir :
I tried the links you have mentioned , unfortunately they do not work.
I am trying to have multiple ROI with the diagram I drew. Could you please guide me?
(2,813 Views)
