Machine Vision
Module Activation
I had to install LabVIEW on another computer, but when I tried to run my saved vis, the IMAQ vision vis were not all installed.  I couldn't find them, so I transferred the vision folder over from an old computer as suggested here http://digital.ni.com/public.nsf/allkb/B23E67C08CBD161886256F82007D58D8
Those vis are now present, but they're not activated.  When I try to activate the module ("The Vision Development Module library"), it shows that all the components of LabVIEW are activated, so there's no way to activate it.
The complete error message I get when I try to run the VI is
"The Vision Development Module library is expired or invalidly licensed on this computer. To purchase this product, contact National Instruments. If you have already purchased this product, select the Help >> Activate LabVIEW Components to activate this product."
Help?
(5,257 Views)
Pretty simple - buy NI Vision Development, use the installer for it, then activate it using the license that comes with it.
Bruce
Bruce Ammons
Ammons Engineering
(5,247 Views)
The problem isn't that I dont have a activation code for it, it's that when I open the NI License Manager, everything there is activated, and I can't see the problem module to activate it.
(5,241 Views)
Accepted by topic author LaurenceD
I just tracked down the CD with the original software.  I took a lot longer than it could have - that's why I tried the method described in the URL.  It had problems, but it's sorted now.
(5,232 Views)
