Machine Vision
Memory problems with IMAQ overlay
I'm using IMAQ and Labview to display overlay on image. The memory usage increase each time I update overlay, even if I use the IMAQ Clear Overlay function. However, the overlay disapears over the image, but the memory usage of Labview didnot decrease.
Message 1 of 10
(4,738 Views)
Hello Philippe,
Thanks for your post, we appreciate the feedback! It appears that you are correct, in an older version of Vision, this was a problem. Since then the issue has been resolved, and the function should no longer display this behavior.
What version of Vision are you using? If you are using a current version, I would like to investigate this further. If it is an old version of Vision, you should be able to resolve the problem with the newer revision of the application.
Let me know if you need any other help!
Robert
Message 2 of 10
(4,729 Views)
I'm using the current version of Vision (NI-IMAQ 3.1)
Message 3 of 10
(4,727 Views)
Hi again,
The issue I was referring to was solved before IMAQ 3.1, so I am going to see if I can find more information on this potential problem, or potentially reproduce the issue.
I will let you know as soon as I know more!
Robert
Applications Engineering
Message 4 of 10
(4,714 Views)
Hi Robert,
My increasing memory problem is not yet resolved. When I renew overlays in my application, the memory still increase and eventually slow the machine. I send a vi that represents a part of my application and do this memory problem.
Philippe
Message 5 of 10
(4,653 Views)
Hello Philippe,
I know that you have IMAQ version 3.1, but what version of IMAQ Vision do you have?
You can find this information in Measurement and Automation Explorer, under the software tab, similar to NI IMAQ.
Most likely, this will be a version 6.x or 7.x
- Robert
Message 6 of 10
(4,632 Views)
Hi Robert,
The version of IMAQ Vision is 7.1.1
Philippe
Message 7 of 10
(4,621 Views)
Hi Philippe,
First, thank you for the feedback. If there is a memory leak here, we definitely want to get that resolved.
Unfortunately, I haven't been able to reproduce the leak in my own test, and the program you posted was very extensive. Are you able to reproduce the problem in a simple program that contains only an image and a small process with the overlay? I am curious to see if this is the case.
Let me know if this happens for you. In the mean time I am going to continue to see if I can reproduce this problem.
Talk to you soon,
Robert
Message 8 of 10
(4,600 Views)
Oh No!!!
The problem was not the IMAQ overlay!! I have removed all IMAQ vi's and the memory leak remains. I'm very shy, the source is the access to the database connectivity. I will check where can be the memory problem. Maybe is only a programmation error.
Thanks for your help.
Philippe
Message 9 of 10
(4,593 Views)
Hi Philippe,
I'm glad to hear we have discovered the source of the problem. Good luck with your application!
Robert
Message 10 of 10
(4,579 Views)
