02-04-2005 02:18 PM
02-05-2005 07:01 PM
02-07-2005 09:29 AM
02-07-2005 09:49 AM
02-08-2005 09:52 AM
@DannyQ wrote:
Hi Bob,
Thanks for using our discussion forums. It sounds like the Vision Assistant should in fact be able to handle your application. If you load in the image with the reticle on it, you should be able to select Image>>Calibrate from the pull-down menu and save the calibration information with the image. From that point on, each image you load in can be calibrated from your original reticle image using Image>>Calibrate From Image.
Let us know if this helps you out!
Regards
Dan
02-08-2005 11:07 AM
02-09-2005 05:18 AM
03-03-2008 10:20 PM
03-04-2008 09:13 AM
03-04-2008 10:24 PM
