Machine Vision
MatchPattern2 memory leak
I am using the following software:
VB 2008 Express
NI Vision 8.5
NI  Vision Acquisition Software 8.6
My program takes an image, locates a pattern, and shows an overlay based on where the patterns were found in real time.  I am having a problem with the memory continuously increasing.  When I comment out the calls to MatchPattern2, the memory usage stays stable.  Below is the relevant code.  Can anyone confirm this issue or offer work-arounds?  Thanks
Public Class LocatePosts
Dim templateImage As New NationalInstruments.CWIMAQControls.CWIMAQImage
Dim patternMatchOptions As New NationalInstruments.CWIMAQControls.CWIMAQMatchPatternOptions
Dim patternMatchReport As New NationalInstruments.CWIMAQControls.CWIMAQPatternMatchReport
Dim post1ROI As New NationalInstruments.CWIMAQControls.CWIMAQRectangle
Dim post2ROI As New NationalInstruments.CWIMAQControls.CWIMAQRectangle
   Private Sub LocatePosts_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
post1ROI.Initialize(My.Settings.post1ROIleft, My.Settings.post1ROItop, My.Settings.post1ROIwidth, My.Settings.post1ROIheight)
post2ROI.Initialize(My.Settings.post2ROIleft, My.Settings.post2ROItop, My.Settings.post2ROIwidth, My.Settings.post2ROIheight)
AxCWIMAQVision1.ReadImage(templateImage, My.Settings.postTemplatePath)
AxCWIMAQVision1.LearnPattern2(templateImage)
patternMatchOptions.MatchMode = NationalInstruments.CWIMAQControls.CWIMAQMatchModes.cwimaqMatchShiftInvariant
patternMatchOptions.NumMatchesRequested = 1
patternMatchOptions.MinimumMatchScore = 700
patternMatchOptions.SubPixelAccuracy = False
SnapImageTimer.Enabled = True
   end sub
   Private Function analyzeImage() As Integer  'locate the posts
        Dim numberOfPostsFound As Integer = 0
        If AxCWIMAQVision1.MatchPattern2(myImage, templateImage, patternMatchOptions, patternMatchReport, post1ROI) <> 0 Then 'causing memory leak
            MessageBox.Show("error finding post 1")
            Return -1
        End If
        If patternMatchReport.Count = 1 Then
            post1.X = patternMatchReport.Item(1).Position.X
            post1.Y = patternMatchReport.Item(1).Position.Y
            numberOfPostsFound += 1
        End If
        If AxCWIMAQVision1.MatchPattern2(myImage, templateImage, patternMatchOptions, patternMatchReport, post2ROI) <> 0 Then 'causing memory leak
            MessageBox.Show("error finding post 2")
            Return -2
        End If
            post2.X = patternMatchReport.Item(1).Position.X
            post2.Y = patternMatchReport.Item(1).Position.Y
        End If
        Return numberOfPostsFound
    End Function
   Private Sub SnapImageTimer_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles SnapImageTimer.Tick     '25ms interval
        errorCode = CWIMAQ1394.Grab2CW(sid, 1, BufferNumber, myImage)
        If (errorCode <> CWIMAQ1394.ErrorCodes.IMG1394_ERR_GOOD) Then
            DisplayError(errorCode)
        Else
            If analyzeImage() <> 2 Then
                'MessageBox.Show("unable to locate both posts)
            End If
            'displayOverlays()
        End If
    End Sub
End Class
(3,744 Views)
Hi Brad,
Could you post an attachment of the simplest code that reproduces the issue on your side?
Jeff | LabVIEW Software Engineer
(3,723 Views)
Hi Jeff,
Thanks for your reply.  I have attached a sample project that illustrates the problem.  I think that I have more or less figured it out now.  Looks like you need to pass a new CWIMAQPatternMatchReport to MatchPattern2 every time that it is called or else the memory usage will increase.  I'm not sure if this is expected or not, but it seems unexpected because you only get the latest match result in your CWIMAQPatternMatchReport when you use it multiple times.
In the attached project if I change the CWIMAQPatternMatchReport to be a local (used only once) instead of global (used multiple times) the memory usage seems to stabilize.
Brad
(3,701 Views)
Ok, I will try it out myself and see if I can reproduce it.
(3,674 Views)
