Machine Vision
Machine Vision fundas - Part I (ROI Manipulation)
There have been lot of fundamental questions asked repeatedly and hence I have planned to explain the some fundamental functions which I also struggled to get while beginning to program image processing.
ROI from Pattern matching
Pattern matching unlike any other programming language is readily and easily available. The struggle comes when we want to extract the matched part or overlay the part.
18017iF783D37CA7672D1C
The pattern matching has an output indicator called matches which is an array of clusters and we have to convert that into a cluster to get the required bounding box. This is explained below
18019i49497BD410D9567A
The template matched can be extracted as well by using an Imaq extract as shown above.
18027i79F4152888D25F71
ROI from Particle analysis
The same result can be obtained by converting the image to a binary image and using particle analysis as shown below
18023i368A81A2F33B79D8
18025iF1B1B394AE13602B
(5,193 Views)
This note is really helpful. Thanks.
(4,922 Views)
