Machine Vision
Labview vision vs acquisition vis
I have a large Labview program (1000+ vis) which does image and motion acquisition and then processing of the image.  I am splitting this into 2 seperate parts.  Acquisition and Analysis.  The acquisition does some simple image manipulation and the analysis extensivly uses the vision processing vis. How do I findout which vis can be called with the vision acquisition liscence and which require the vision development runtime?  I would like for each part of the program to only require one lisence since they will be distributed over two physical PCs.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,426 Views)
Hi, Paul,
Refer to this KB Article: Which VIs are Installed with NI-IMAQ and Vision Acquisition Software?
Then you should check dependencies - that you haven't used Vision VIs in the acquisition part.
Andrey.
(3,424 Views)
Thanks This was what I was looking for.
Paul Falkenstein
(3,423 Views)
