Machine Vision
Labview Interface with Cognex
It's an Insight Cognex camera. now i try to use telnet commands to see if it's working. thank you!
Message 11 of 20
(7,241 Views)
HI i connected Labview with Cognex using .net .
but the cognex display image takes so much time .
Message 12 of 20
(7,220 Views)
can you elaborate on this?
what takes time? i have used this before and its works in real time for me. is it not the inspection processing time that is long?
Message 13 of 20
(7,213 Views)
Hello, you can insert code vi Please....
Thank you very much.
Message 14 of 20
(7,114 Views)
I am trying this too ..
I would like to have labview communicate with : http://www.cognex.com/products/machine-vision/in-sight-5000-industrial-vision-systems/
If you have done it, and can share the VI, that'd help me get started.
Thanks.
Message 15 of 20
(6,803 Views)
Sorry i dont have the vi anymore, but there are two ways of doing it.
either buying the Sdk or using the native mode commands, the sdk allows you to acces all the features and get the image and spreadsheet into labview, native mode just allows you to pass data to and from the spreadsheet and change jobs.
i can supply the sdk, get in touch if you need it.
Message 16 of 20
(6,797 Views)
Sorta new on here , how do i get in touch with you? I can get the SDK and take a look at it (to see if its useful)
Message 17 of 20
(6,740 Views)
Have a look here: http://www.cognex.com/support/downloads/File.aspx?d=3127
you may need a license to use it though
Message 18 of 20
(6,736 Views)
I know of that.. if I had the licence, would I be here?
Thanks anyway.
Message 19 of 20
(6,734 Views)
Its €1200 if you want a copy
Message 20 of 20
(6,724 Views)
