Machine Vision
LabView 8.6 and Vision Development Module
Dear All,
I'm using LabView 8.6, but the vision function is no included. I want to buy a software, what software that I have to get it? From the Ni website, I found the Vision Development Module. Can I use it with LabView 8.6? I also want to know, can I use the Vision Development Module to program my machine Vision intergrated RTV-series Adlink frame grabber?
(4,241 Views)
Current version iof Vision Development Module, VDM, is 2009 which supports LabVIEW 8.6.
Therefore, you should not have software compatibility problem.
VDM itself is image processing software.
It has nothing to do with image acquisition.
You must check with Adlink whether how can itg pass an image to LabVIEW, and in which format?
Another thing to mention here is that VDM 2009 includes Vision Acquisition Software 2009 which is compatible with third party IEEE1394 and GigE.
Therefore, if you use these type of interfaces, it'll be very much easier for you, but if you need to stick with analog camera which is supported by RTV, I'd recommend consider using NI frame grabber as found in http://sine.ni.com/nifn/cds/view/main/p/sn/n21:11600/lang/en/nid/1286/ap/vision/ps/25, since they're fully compatible with LabVIEW.
(4,220 Views)
Hola gente de labview, queria saber si alguine me puede ayudar con una duda, bien, lo que pasa es que estoy realizando una aplicacion de vision artificial con una webcam para reconocer unas piezas (circulo, cuadrado y triangulo) y despues clasificarlas. las piezas se mueven atravez de una banda transportadora. la aplicacion de vision artificial me funciona bien el problemas es que estoy manejando un motor de pasos y lo estoy comandando atravez de un modulo USB6008, y lo que pasa es que cuando ejecuto el VI para la aplicacion de vision artificial el motor de pasos gira demasiadamente lento y sin correr el VI de el programa de vision artificial el motor de pasos y la banda transportadora gira muy bien, no se si sea cuestion de memoria ram o que. a ver si me ayudan con una solucion.
estaba pensando manejar una sola salida de el modulo USB 6008 y mandarle a un PIC para que este sdea el que genere las secuencias del motor de pasos, esto en el caso de que no haya otra solucion dentro de labview mismo.ç
Gracias.
Saludos.
Edgar Lojan.
Best Regards.
Ing. Edgar Lojan
(4,203 Views)
