Machine Vision
LCD screen
I want to scan an LCD screen and inspect each and every pixel in it.
I have to pick all the bad pixels on the LCD screen. I need is a
idea or an algorithm of how to go about this problem. I would capture
the LCD scree using a camera. I have Labview vision developement
module.
(4,621 Views)
- Fill your LCD screen with black
- Snap image, apply threshold and check that you haven't white pixels
- Fill your LCD screen with white
- Snap image, apply threshold and check that you haven't black pixels
Done!
Andrey.
(4,617 Views)
Audrey thanks for your quick answer. I have
been very confused with the thresholding of
an image. Is there an auto threshold option
or do we always need to manual threshold
for these type of applications. I had a similar
idea but had difficulty in implementing it. If you
could help it would be great.
Yesh
(4,610 Views)
What I meant above was do you have an idea or
an algorithm with which I could implement this
in labview. I am new to labview
(4,605 Views)
If you have the Vision Development module, there is the IMAQ Threshold VI.
Jeff | LabVIEW Software Engineer
(4,585 Views)
I will suggest you play around with vision assistant and get a grip. You can also generate lv code from vision assistant. You can optimize it later anyway.
(4,522 Views)
