Machine Vision
Known memory leak
What are the memory leak known today for the IMAQ VISION library... for CVI...
I'm having a memory leak and I start to suspect IMAQ VISION
(3,230 Views)
StephDesj,
At this time, I am not aware of any memory leaks that exist in IMAQ Vision. If you believe that you are seeing a memory leak, please try to focus in on the function or functions that you think may be causing the memory leak, and post the names of those functions and an example that demonstrates the problem. If you do make such a post, please include the hardware and software versions that you are using so that this forum can help you debug the issue or verify the memory problem.
Jed R.
(3,230 Views)
