Machine Vision
KnowledgeBase article for RT targets is outdated?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KYuSAM says that "Since there are currently no sbRIO targets with two ethernet adapters, IP cameras are not currently supported on sbRIO."
However, https://www.ni.com/en-au/support/model.sbrio-9603.html has 2 Ethernet adapters.
Would someone kindly confirm if the information on the linked article is still current, and update it if it's not?
Certified LabVIEW Developer
Message 1 of 1
(1,575 Views)
