Machine Vision
Issue routing trigger to camera
I am having an issue routing a trigger signal to my camera through RTSI/CC. Relevant VIs are attached. I have gotten this vi to work previously, but I am trying to apply it to a new camera on a new computer. I have configured the frame grabber in MAX as shown in the attached image so I believe the signal from RTSI 0 should be routed to CC1  (which is the correct line for an external trigger for this camera) yet, I continue to get a timeout error. Any suggestions on how I can troubleshoot this issue further?
Thanks!
(2,232 Views)
Hi Gavrielle,
I believe we solved this issue in an SR. The issue was that you selected the wrong PFI line for the digital trigger. You had selected PFI4 instead of PFI14.
Ahmad
(2,105 Views)
