Machine Vision
Is it possible to automatically select ROI's, and then obtain greyscale histograms for these ROIs
Your original image was saved in JPEG, which is quite lossy.  You might want to post a higher quality image saved using PNG or BMP.
If the find circles routine is not good enough, there is another way to do it.  All of the drops have a very distinctive feature - they have a black ring at the edge, surrounded by a white ring of background.  You could generate a template for pattern matching that only searches for this feature, ignoring everything inside the drop.  You would have to generate a template for each size of drop, but that could be done automatically since you are looking for high contrast circular objects.
Once you have your drops located, I would consider examining concentric rings within the drops.  For a liquid drop, each concentric ring is about the same brightness with very little variation.  For a frozen drop, there is quite a bit of variation.  If there are noticable edges in a clean image (can't tell from JPEG image), concentric rake might pick up any edges that exist very easily.
If you are serious about hiring a professional to do this for you, I might be able to help you out.  Send me an email (address is in profile) and we can talk.
Bruce
Bruce Ammons
Ammons Engineering
Message 11 of 11
(884 Views)
