Machine Vision
Invert Strobing Signal
Hi all,
I want to invert Strobing signal in my Basler A622f Camera. How should i do this?
i am using Labview 2011.
Thank You.
(3,272 Views)
You should be able to set the trigger to Rising/falling edge.  Check the camera documentation, and the settings in MAX.  If not, you will need to build a simple circuit to inver the signal.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(3,089 Views)
