Machine Vision
Interface cognex developed application to Labview
Hello all,
In my application due to customer requirement we are using cognex quick build for image process and labview as front end.
Can anyone guide me how to call a cognex jobcode  *.vpp from the Labview.
I am using labview 7.1
Message 1 of 21
(11,380 Views)
HI ,
Have you got solution ?
Message 2 of 21
(10,106 Views)
I don't think you can call a VisionPro file from LabVIEW direct. You would need to build it into the Visual Studio app or .NET assembly and then call it from there through the .NET api probably.
From what I rmember the VPP is just a configuration file for VisionPro to run. There may be a .NET assembly for VisionPro that you could then load the vpp file into and run, Much like you can do with VBAI.
Mike
Message 3 of 21
(10,101 Views)
HI MikeeB,
yes i need to run .vpp file using labview .net ,
but i am not able to connect labview with cognex, do you have any labview example file for labview + cognex quick build using .net
Message 4 of 21
(10,086 Views)
Sorry I don't have access to VisionPro anymore. I would look at the VB.NET examples that come with it to try and find one that loads in a .vpp file and then runs it.
Then use the .NET example Calling a Private .NET assembly VI you should be able to see how to call the relevant methods.
Good Luck
Mike
Message 5 of 21
(10,063 Views)
HI Mike ,
i have used .net platte to run .vpp file.
but i am not able to get output image and .vpp file output .
How to get process image output and results of the .vpp file
Message 6 of 21
(10,060 Views)
There should be a results object that you can retrieve from the job manager after that. You should also be able to reference the image output of a step. This is all from memory as I haven't used this in 10+ years
Sorry I can't be more exact
Mike
Message 7 of 21
(10,051 Views)
Mike ,
thanks for the reply
Message 8 of 21
(10,048 Views)
can you share  your Vi to me ,  I want to know how to call VPP  in labivew .
wenluderen@gmail.com  is my  E-mail.
Thank  you
Message 9 of 21
(8,858 Views)
Will you implement visionpro call with LabVIEW.net, can you give an example program, I now use "loadobjectfromfile" but unsuccessful, thank you!
Message 10 of 21
(8,761 Views)
