Machine Vision
Imaq usb menu not found
Hi All:
   I have Labview 8.2 , Ni-IMAQ 7.1.1 and NI Vision Assistant 7.1.1,  but I cant find the IMAQ USB menu as refered in the NI-IMAQ_for_USB_Cameras_User_Guide.pdf
Any Idea how to fix it?
Thanks in advance
Francisco
Message 1 of 10
(5,187 Views)
Hi there,
The USB menu does not appear until you install the USB drivers.  These are a seperate entity to the NI supplied Vision drivers.
Hope this helps
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
Message 2 of 10
(5,180 Views)
Thanks Adam for your quick response.
     but I have already installed the USB drivers, that is where I get the NI-IMAQ_for_USB_Cameras_User_Guide.pdf.
Thanks anyway.
Francisco
Software Engineer
Motorola Argentina
Message 3 of 10
(5,176 Views)
What version of LabVIEW are you running?
AdamB
Message 4 of 10
(5,173 Views)
Hi Adam
I have Labview 8.2 , Ni-IMAQ 7.1.1 and NI Vision Assistant 7.1.1.
Message 5 of 10
(5,171 Views)
Once the installer finished, did it tell you where the USB drivers were installed?
Try installing it again and the very last screen from the installer (Installation Complete) note down the locations the USB drivers have been installed.
Then navigate to the appropriate directory.  Are the files there?
AdamB
Message 6 of 10
(5,167 Views)
It says C:\Program Files\National Instruments\Vision Assistant 7.1
What files should be installed there?
The USB webcam works fine in the Vision Assistant, but in Labview I cannot find the VIs..
Francisco
Message 7 of 10
(5,165 Views)
I am using Labview 8.5.1 and having the same problem. I have installed the USB drivers for IMAQ but still lack the USB menu.
Message 8 of 10
(4,545 Views)
Hi alang,
Does it work in vision assistant for you?
Message 9 of 10
(4,500 Views)
Hi there,
Yes it works on vision assistant 8.5 when I run it externally, apart from Labview.When i choose the acquire tab, I can even choose to acquire through USB and I can see the video playback onscreen.
When I use the labview vision assistant icon though, I am stuck on the process image tab with all other tabs and most of the functions greyed out. And of course, the USB submenu is missing.
Message 10 of 10
(4,498 Views)
