Machine Vision
Images no longer transferring across network
Now then,
Up until recently i've been having problems with my PXI unit...none of the vision examples would work on it. It turned out that I didn't have the correct IMAQ RT drivers installed. One thing that did work however was sending images from the CCD, via the PXI box, down the network, to the screen of my host computer. Now that everything is working, all IMAQ VIs display the image on the monitor connected to the PXI unit (via the RT video out), which is great! but I can't get anything on my host screen! In MAX i've got it set to 'transfer images across the network'. One example in particular is the Real-time example under the IMAQ folder in Labview 7.1 which allows you to display the captured image(s) on the RT video out, the host, or both. But I can now only display on the RT video out, whereas before the box was fixed I could only display on the host!
Any ideas anyone?
Cheers,
Rob.
Message 1 of 1
(3,057 Views)
