Machine Vision
Image queuing troubles
I have been making a LV vi to both grab images from my FLIR camera and then do some analysis on them in parallel using a queue system. I am sorry to say that my LV skills aren't very good.
My image queue does not seem get larger as I aquire images. Right now the vi only analyzes the first picture after I hit my start analysis button, what I would like is a continuous analysis that feeds from the queue of images that are being taken in real time. Below I will attach my vi so far. Any help or suggestions on how to make the analysis to repeat itself would be great.
Edit: wrong file attached
Message Edited by JustK on 09-21-2006 10:57 AM
Kristjan
(3,050 Views)
You have your dequeue element outside of your while loop.  Therefore you are only taking the first element out of the queue and then processing that.  Move the dequeue element inside of the loop if you wish to take an image out of the queue with each loop iteration.
Christopher W.
(3,022 Views)
