Machine Vision
Image library question
I am developing a Labview program to acquire image from webcam. I download the program from MindofPete.org (famous Labview Webcam Library), but during running the program, it reported lacking Draw Flattended Pixmap.vi and Empty picture.vi. Heard that that is due to lack of image library. My labview is the basic version. how can I get those image library?
Thanks very much!
LY
(3,548 Views)
From what I can tell, Pete answers questions at the following address: parenp@alum.rpi.edu. However, his code makes use of the LabVIEW native Picture Control, which comes with the Full version of LabVIEW. You will need to upgrade your LabVIEW in order to use Pete's code.
Kyle V
(3,548 Views)
I'd like to add that I've never actually used this toolkit from mindofpete.org, so I'm not sure if or how it works. If anyone here has ever used it before nd gotten it to work, I'd be interested in hearing about it.
Kyle V
(3,548 Views)
usa wrote in message news:<506500000008000000F7790000-1042324653000@exchange.ni.com>...
> Thanks very much!
> LY
You probably don't have the picture pallete for your basic version. I
have a library work for webcam too without needing the picture
functions. You can check it out if you want:
http://www.geocities.com/irene_he/IVision.html
Irene
(3,548 Views)
I've used both Pete and Irene's toolkits (they are featured in "Image Acquisition and Processing with LabVIEW" - see <> for more details), and they both work fine. Pete's toolkit is an excellent interface to just about any camera you can access with Windows and is free, whereas Irene's toolkit has image acquisition VIs, and a full image processing suite (similiar but not as comprehensive as IMAQ Vision) and is liscensed.
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
International Voicemail & Fax: +61 2 8080 8132
Australian Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed wi
thin it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,548 Views)
