Machine Vision
Image duplicates and Get Image error
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11">I’ve build a classic machine vision application with CVS and Marlin 131b. The image acquisition is triggered by a photocell connected to CVS. The processed image is stored remotely (via datasocket) with their data results. Occasionally the follow problem occurs: in my image folder (onto PC client) I found image duplicates.
Notes:
    * The distance between camera and CVS is 10 meters
    * There’s some electric motor near the camera and CVS
    * when the problem occurs Get Image VI generates an error, the same error that is generated when the camera not listen the triggering signal
It is possible that the problem is generated by electromagnetic noise or it’s a software problem?
Any idea?
 Thanks, fabiomal
(3,391 Views)
Can you tell us what error you are getting?
(3,389 Views)
Seems some problem with your pasting .Can you post it again?
(3,387 Views)
Sorry ...
I've build a classic machine vision application with CVS and Marlin 131b. The image acquisition is triggered by a photocell connected to CVS. The processed image is stored remotley (via datasocket) with data result. Occasionally the follow problem occurs: im my image folder (onto PC client) I find image duplicates.
Notes:
    * When the problem occurs, Get Image VI generates an error, the same error that is generated when the camera not listen the triggering signal (I don't remember the error code, I will post it as soon as possible)
Any idea?
 Thanks, fabiomal
(3,383 Views)
